rolopolo
Established member
- Joined
- Jan 9, 2012
- Messages
- 837
- Points
- 308
A little advice.
Take out your passenger headlight,
Unbolt the ECU plastic cover,
One of the main Wiring looms to the ECU is cable tied from factory to the metal ECU mount,
Cut this cable tie
Check wiring hasn't worn through from chaffing against metal bracket
I've just had a new turbo fitted, to find the wiring had worn through over time, most of the wiring was green and corroded, auto electrician had to make new loom up for certain wires.
Still at least I've a new turbo and know she's good for another 360,000 miles (I wish)
Worth checking if you have other faults too
Cut this cable tie
