Technical X250 Boost Pressure Sensor Location
07Ducato
Hi All
Need your help if possible, I have a 2007 Ducato self converted camper and EML came on Yesterday
. Sods law as we are due to go away tomorrow for the Easter weekend
I have just been out and tried to clear it but its showing as still active, Fault code is P0235 - Boost Pressure Sensor, So can anyone point me in the right direction whereabouts it is?
Another job that I need to do is enter the Injector correction codes into the ECU, I have had a look on MultiECUscan and it says the code should be a 9 digit alphanumeric code but the codes stamped on my injectors are only seven digits long
Thanks in advance for your help
You need to clear the whole intake manifold like I did , thats all!
Not enough to change the sensor... look attached pictures I made today
