Technical X244 wiring diagrams in eLearn not working any more?
Ocwobio
Established member
Hmm. As per title. It used to work flawlessly until about 10 days ago, but now all I get is an image place marker in the top left hand side of the border. I have evem downloaded and re made the .iso file, without any corruption warnings or failed downloads, so I have no idea what has changed. I have not removed any unrelated things like a browser, acrobat, or such like and don't really know what other add ons are pre required. Java and runtimes etc are all up to date.
Not had this before. Using Gburner virtual drive to mount .iso image and can access eLearn as usual but no diagrams now. There always was some stuff missing, but that was a constant and is still the same, but this latest in the electrical/wiring diags is new and has me stumped. Anyone had this and resolved it? Thanx folks.
Reinstall the png viewer that comes on the CD or install latest version of it (listed online as obsolete)
Hi Corcai not got a cd, did it by knocking up .iso file. So I have re downloaded the parts and done new iso, but still persistent probs. I have several viewers tah do png's bt guess I need the right one? Have you a link to a workable viewer or such like please? I may reluctantly roll back the PC to 2 weeks ago when it all worked. In hindsight, I tried to install Renault dialogys which failed, IIRC thats when problems may have started. Since removed it now this.
Communicator- tried the Russian eLearn link you posted, but similar probs, wiring diags just show component locations. Cheers folks
Sorry meant svg not png earlier. You can also download the newer version on Adobe site: https://www.adobe.com/devnet/svg/adobe-svg-viewer-download-area.html
No probs mate. I reinstalled svg from my iso image. However, it seems I am, or may be, mistaken in thinking I knew where the diagrams are. I go into the left hand menu for 'electrical equipment'/ 2. wiring, then only get parts location pic for items selected- not wiring diagram. Is this right? IIRC this is how I got to the wiring diagrams. But there are hardly any in that section. I have seen the cruise control diagram, but now can't find it again, and also need brake light switch wire colours too.
Ocwobio,
Try 1. Electrical Functions. Then E50 Engine Control and Management Systems. Cruise Control is E5060. Brake lights are under external lights E20, diagram E2021.
Slight pause while I rescued my brake light switch scrap view from WPB.
Index is adjacent to pin 1. Connections are pin 1 Gy/Bk (HN) to EMC A54 via D001B/1, pin 3 Light Blue (A) to Cruise Control switch stalk via D160A/1, pin 2 Rd/Bk (RN) to brake lights, pin 4 Bl/Gn (LV) brake light supply from F26.
Designated cruise control supply is from F27 to D160A/6 Wh/Bl (BL). I linked this to pin 1, but access is difficult.
If opting for a link at the switch to take a supply from F27, you will need to link blue to blue/green close to the switch, and extend to Alfa stalk yellow wire.
Got them back,,,,looking in wrong place. Senior moment! Thanx to all my helpers, as ever.
I will add that this is the most active and responsive of all the fora I use, what an excellent bunch all round!
