Technical  Wishbones
Technical  Wishbones
I think they're unique to the Multipla, though it's possible they share them with the Tempra - the polybush kits for the two are the same. Have you tried looking up the part numbers on ePER?
I need them for the marea and they seem to be cheaper for the multipla than the bravo/a and marea ?
Ah, I see.
What connects/mounts to the round hole in the arm on the Marea wishbone?
That seems to be the only visual difference with the Multi version . . .
ePER's coming up with the same part numbers for the Brava & Marea wishbones, but not the Multipla, even if you look back through previous versions.
The Multipla is of spaceframe construction, so saying it's built on the same platform as the Bravo/Brava/Marea isn't strictly correct. Looking at photos of the Marea subframe, I'd say it's different to the one for the Multpla, especially across it's back edge.
Have you got an old Marea wishbone to take some check measurements from?
