i need a hand with setting up the wiring and fueling for for my engine.
lts start with the fueling, on the standard cinq there is two fuel pipes that go on to the throttle body im guessing that one is the feed and the other is the return well on the 16v engine i can only see a feed do i just block off the return pipe or what.
the wiring, i have had a lot of trouble trying to get a wiring loom from a punto 1.2 16v mk1 so i have had a thought, will a seicento mpi wiring loom do the job are the sei mpi's fly by wire ir throttle cable.
cheers gregor
cheers gregor
