Technical Wirind double din stereo
Sputnik1
Hiya,does any1 no how to wire a double din stereo. I bought a harness for my double di satnav and all was fine. Then 1day the battery went flat and again a week later. I bought a new battery an all was fine an then it went flat again a few times. I was just bout to change the alternator but put the old blue an me stereo back in out of curiosity. Now been 2months an car has been fine. The stereo i got frm hong kong must be goin str8 2the battery and still usin power even thou its turned off. I was gonna wire it to the cig lighter but its to awkward to get too. Iv a fiat bravo 1.4active 2007. Any ideas would be great. Thankyou.
The Bravo doesn't have a switched 12v on the ISO connector to turn the head unit off, you need to find a switched live or turn the head unit off manually.
The stereo has to be turned on and off manually. I hav been told that i could run a wire frm the electric windows and then the stereo would turn on an off with the ignition so mite try that.
NO NO NO!!!!!
DO NOT wire it into the electric windows. Who ever told you that needs shooting, the electric windows work on a very sensitive canbus network! Wire it in directly to the ignition switch, or into the cigarette lighter / power aux which is ignition switched (y)
Is their another wire i can connect to rather than the cigarette lighter as that is quite awkward to get to. Thanks for the advice guys i def wont try the electric window.
