General  Wipers!
General  Wipers!
Ashley1
Hull
Hi guys!
My drivers wiper seems to be a bit sticky at the bottom of the windscreen and at a couple of points, the near side one seems to hit the driver side, is this a known problem? Or should I just maybe change the blades?
I had a similar problem when I bought the car a few months ago and realigned them to the dots and it sorted the problem. Since then the wipers have whistled from 70mph upwards.. Good speed deterrent but very annoying!
I have had them at different angles but can't seem to shake it. Anyone else have this problem? It may just be the bosch wipers..
I've read that a few people have swapped the passenger wiper for the 500 14" blade, could be worth a try!
The whistling could just be could be coincidental and not related to the wipers at all. When I had whistling on my bravo I found It was the bonnet lip being slightly raised and air was getting underneath it and whistling. Took me about 2 minutes to realign the bonnet latch. So the bonnet sat flush to the bumper. No whistling even at 110MPH+. Not that over tested those sorts of speeds obviously
For an easy fix to the wiper issue try the smaller Fiat 500 passenger wiper. For the whistle open the bonnet and tighten the two rubber nuts that rest the front of the bonnet on the bumper.
