General  Wipers
General  Wipers
carl2745
just wondering if anybody fitted areo wipers to there multipla was just wondering about the retaining clip on the driverside cannot get it to fit.
Yes, Bosch aerotwin retrofit. Just fitted a new pair yesterday. The old set lasted pretty well (about 2 years I think). They make less wind noise than conventional wipers too.
The fitting method is the same for both arms. Very simple to fit. What's causing the problem?
I think Carl's referring to the little 'hook' fitting on the driver's side arm, it stops the blade twisting on the up-stroke, preventing the l/h end from catching on the other blade.
I would think the 'Aero' blades are stiff enough not to need it.
Are those Aero/Flat blades really worth their extortionate price?
I pay a couple of quid twice a year to replace just the rubbers on mine.
The others would have to last about 8-10 years to be the same value . . . :yum:
I like them. £18/pair, delivered. They wipe evenly across the entire blade length, don't judder, make less wind noise on the motorway and don't lift at speed. The fork/hook on the drivers side wiper arm sits astride the spine of the aero wiper a treat, holding the blade in place.
If you're running your Multi on a shoestring, they're a needless extravagance. I drive a cheap car and spend some of what I save in maintaining well. You pays your money, you takes your choice.
