rickeb said:
Yea i think thats them but most are the same!! i tried swapping them around but things are still the same..there are only 3-4 different ones and im not sure how to test them. Im wondering if the stalk itself is faulty?? Is there any way to check the stalk that anyone knows of?
LOL... did you just randomly swap them around? If so... errr...... hope everything that was working still does
Firstly, you wipers should return to the bottom of the windscreen when you turn them off, since your don't, I suggest the self parking mechanism is broken, if you search the forum (some of the more popular sections) you may be able to find a way to test this.
Secondly, if the intermittant mode isn't working, I suspect that the stalk may be faulty, this is quite a common problem with fiat (especially if its a twist one rather than the lever style stalks, if you get me). This may solve your rear wiper woes as well.
I remember that either Unos or Tipos have dodgy windscreen seals that allows moisture to get into the drivers side foot well (where the fusebox is) which can, over time, cause the fusebox to chorode, and stop working properly, in which case you may be in for a new fusebox, although I'd try and get one from a scrap yard as Fiat charge about £200 for em. You should first try and get a copy of the workshop manual with a wiring diagram so that you can identify any relays that may require replacing BEFORE you replace the fusebox itself.
A tell-tale sign that the windscreen seal is faulty is that the lower parts of the windscreen will be visibly cloudy from the outside in the corners, where the seal meets the body.
Here are a few links that may help you:
https://www.fiatforum.com/showthread.php?t=18606
https://www.fiatforum.com/showthread.php?t=11783
Hope that helps
