Speedbird643
- Joined
- Jan 10, 2008
- Messages
- 3
- Points
- 1
Hi there.
I have owned my MkII Punto since 2002, and have covered 30000 miles in it; however last weekend it developed its first issue.
While using the wipers last weekend, they decided to ignore the settings I chose. Generally, if I select the slow setting then they run slow for a while, before deciding to switch to constant. If I use the single sweep function, it works most of the time, however sometimes decides to operate continuously for several more sweeps. Additionally, they are failing to stop when I turn them off, usually for about 2-3 minutes.
Commonly they are not returning to the stowed position either, just stopping dead in the middle of the screen.
Is this a problem that is reasonably easy to fix, or would I be better taking it to an auto-electrician for a check in case it leads to any other issues?
Thanks for any assitance
Martin
Martin
