500 (Classic)  wingless' 1968 Fiat 500L
An additional vehicle was required to be added to my "fleet" like I need a hole in my head, but I saw this gorgeous 1968 Fiat 500L and I decided it needed to be mine. For me the amazing condition of the vehicle was the driving factor on this purchase.
This is my first Fiat and my first Italian car.
It will be collected from the seller, World Imports USA shortly using a U-Haul 6x12 Trailer w/ Ramp, pulled by my daughter's 2021 Ford F-250 Truck w/ a Weigh SafeDrop Hitch, so I can get the front / rear placement correct for appropriate tongue weight. Her truck has an unused 2½" square hitch receiver, because it has been used exclusively to tow using a gooseneck hitch in the bed.
This Amazon wheel tie down kit will be used, along w/ ratchet straps to the front and rear underbody tie downs to secure the vehicle to the trailer for the ~3 hour ride home.
A custom fit California Car Covers Supremeweave w/ Flannel Lining car cover is on order and will be used to protect the clean vehicle between usage. I use these covers on all my vehicles and they always look brand new prior to each usage.
My plan is to add three point front seat belts in the near future and maybe also rear lap belts. I have already read all the great topics in this forum on that modification.
"It will be collected from the seller, World Imports USA shortly using a U-Haul 6x12 Trailer w/ Ramp, pulled by my daughter's 2021 Ford F-250 Truck w/ a Weigh SafeDrop Hitch, so I can get the front / rear placement correct for appropriate tongue weight. Her truck has an unused 2½" square hitch receiver, because it has been used exclusively to tow using a gooseneck hitch in the bed.
This Amazon wheel tie down kit will be used, along w/ ratchet straps to the front and rear underbody tie downs to secure the vehicle to the trailer for the ~3 hour ride home."
The 1968 Fiat 500L was collected using the 6x12 U-Haul trailer and the Ford F250 for what had hoped to be a 3 hour drive, except the highway was closed / empty in the opposite direction for an accident, also impacting the travel time in my direction because of the high content of rubber in the necks of those sitting behind the steering wheel.
The Fiat was backed onto the trailer, to maximize the tongue weight, with my assumption of the rear weighing more than the front, but the tongue weight was still less than ideal. The trailer weighs 2,290 lbs, the vehicle 1,100 lbs and the tongue weight should be 340-500 lbs.
With the vehicle bumper an inch from the inside front trailer wall the tongue weight was measured at only 250 lbs. Even though the tongue weight was less than ideal, there was no stability issue when towing.
Note the detached ball carrier is shown at the highest position, but it was lowered three holes during usage to level the trailer.
Always use a spotter when loading or unloading.
The vehicle was tied down at each wheel, plus also at the front and rear underbody body tie down brackets, for a belts and suspenders approach. There was zero transportation movement of the vehicle on the trailer.
Very good, seems you have a perfect one. First impressions tho it looks like the rhd door is filled, but maybe wrong.
I hope it gives you many enjoyable miles and smiles.
Mine was 1967. Barry
My Fiat spent most of it's life in Italy, in the Province of Viterbo, w/ the black background / white embossed text plate shown in the images.
That plate is gone, but I would like to have it recreated. Are there any contacts for fabricating that part?
Nice! My '71 500L was first registered in Viterbo (before 45 years in Rome, then to the UK).
Re license plates - there's a place in the US advertising to make replicas, though not cheap... https://www.licenseplates.tv/antique-italy-plates.html
EXELLENT info, thanks very much.
That looks like exactly what I've been seeking.
Any after-hours inquiry is now waiting attention in their In Box.
JUST spoke to that replica plate company. They called regarding my E-Mail and confirmed they will produce an exact replica. That was ordered and should arrive in about a week.
They sound like a top notch organization.
That new replica license plate arrived in less than a week. I am VERY satisfied w/ every aspect of this purchase. The accuracy is spot on, both on the website and the finished product implementation. I have zero reservation recommending this company.
Images are attached showing the finished product of my replica embossed front license plate.
The manufacturer embosses a circle, then places a decal for the Italian Republic emblem, the "RI" in a five pointed star surrounded by garland.
This replica 1932 to 1976 Italy mini Euro plate is smaller than current / modern Euro license plates. Those modern plates are mechanically secured to the vehicle at the perimeter by the license plate bracket / frame. The manufacturer specifies usage of two-sided tape for attaching this smaller plate to the vehicle. Tape doesn't seem appropriate or secure enough. Also, tape wasn't used decades ago.
My Italian brother-in-law says that a slide-on frame was / is used to attach that old / smaller plate to the bracket. My vehicle doesn't have such a secondary attachment frame, just the original plate bracket.
The image of the original plate appears to show mounting screws in all four corners.
The vehicle is currently garaged several hours away, so a detailed mounting / attachment options examination will be delayed.
Original Front License Plate
Currently Empty Front License Plate Bracket
New Replica Embossed License Plate
Great to hear you had success with that replica company. I have been eying them myself too, as i have the original front plate, but would like a reproduction original style rear to put on the car. Or more so, get a full reproduction set, and keep the original in its car binder.
One unfortunate thing is. For the price, im disappointed that the Republic emblem is just a sticker and not painted on like the original. Might not seem like a big deal, but i was hoping it would be painted.
If a painted Italian Republic symbol instead of the decal on this part is required / desired then peel off the decal and have a silkscreen company custom screen print the symbol on the white background. There are MANY companies doing that work.
IMO it is a small enough feature for the usage of a label to not detract from the part.
IMO it has an infinitely superior appearance to the original part and that finish quality difference is a much greater detraction for those seeking to maintain originality than any symbol decal versus painted concern.
53474874380_99e0fe6e29_c-jpg.436884
53474454666_ef153a2d83_c-jpg.436885
Are they stamped sheet metal or vacuum formed plastic like the originals? Looks like metal in your photos
The old original plates shown in the prior post is plastic, not metal?
