Windscreen Washer Pump
J
Jordy
My windscreen wipers have stopped working.
Anyone know the part no. for the pump & cost???
Cheers in advance
about £15 tops. Did one on a sierra a couple of years . I dont know the part number for your bravo one though though.
Buzz (formerly LightWarrior)
The champion of the Bravo 1.4
Owner of the Bravo 1.8
Member Page
Ok is it that your windscreen wipers dont work or is it the windscreen washer pump thats not working.
When i bought my JTD the windscreen washers where not squirting water, neither was the jets blocked and the motor made no noise.
I assumed faulty pump, but then took the contacts off, cleaned them and made the connection tight, the pump has never skipped a beat.
If your windscreen wipers aren't working then you need a motor. I have a front windscreen motor, but not sure what its worth.
Joske
oh, i thought it was just the water pump. The motor for front wipers is £90 new from fiat!
30 min job to replace though
Member Page
Yeah my wipers work fine....also checked the fuse, as the pump made no noise at all.
I tried the washers this morning and checked the contacts on the wiring and they worked first time.
Problem sorted. Cheers for the info guys.
M
7K
M
T
1
617
A
T
1
569
Joseph
J
