Windscreen Washer Problem
  • Thread starter Alan H
  • Start date
  • Replies 3
  • Views 531
A
Alan H
hi
my windscreen washers stopped working recently and i thought they just needed filling up....
i filled the resivoir up and they still dont work so i think maybe the motor has gone???
really unsure...is it something i can fix myself? if so how?
could it be at all related to recently putting in Marea lights?
Alan H
First check the fuse, then listen if the motor works, then check your pipes to the jets - they are under the fabric on the bonnet
Members Site - - - - - - - My Site
Happened to me twice........
On the reservoir, you will see the two pin black plastic connetcor. Take it of, clean both reservoir terminals and connector - get the WD40 out any away you go.
Failing that, as our learned colleague suggests - fuses!
cheers guys - will do this later and failing these ill be back no doubt
W
1K
wakka
W
T
1
1K
A
T
1
941
Joseph
J
P
6
733
P
