Technical  Window problems
DarrenL55
Stranraer
my window control panel on my drivers side down not work at all not even the locks for the back door and side door. But passenger side works fine I drive a Fiat doblo van
If you hold your finger on the button and open and close the door can you get the window to operate at certain angles? If so it’ll be door wiring inside the rubber boot. Not sure if this is a common problem in the Doblo?
Very common in mine. Passenger window doesn't work and i can sometimes hear something clunking away in the door.
One side door lock is stuck open. Other side and rear got stuck locked and could only be opened from the inside. I managed to fix those two - one was seized up, the other the cable had come loose. Not easy, especially the side door.
Window and open lock - both passenger side - I tried fixing, but gave up. I can live without them working. Spent enough on this bloody thing.
