General wind noise from drivers door
milfy
Cardiff
been out in 500 done 500 +miles now and noticed a wind noise from top of drivers door:confused: all rubbers are ok and cant see what is causing this noise :(
dont want to bend top of door as it may break paint any ideas or is it back to dealer for this :rolleyes:
i bought a new fiat panda in 2007,it always had a wind noise/whistle which i thought was coming from the front passenger door,i tried putting masking tape over the door gap to try and locate the whistle but could not find it.then one day when washing the car i noticed the passenger side windscreen wiper was in a slightly higher position than the other,so i undid the fixing nut and moved the arm on its spline.and this totally eliminated the whistle.hope this might help.(y)
I think you will get this in most cars I have a mk v golf and my drivers door does it on and off. Sometimes it's quite loud and other times you don't notice it. When I drive lindas 500 I do listen for this and I have to say it's really quite quiet, when the speed rises you can hear it a bit but nothing to shout about :)
the noise is right in the top outer edge of the door may have to give it a tweek to rectify i got a few vehicles and its only happening on this one
pass side is quiet as said before ,if that fails ill turn up the music :D:D:D
or stick some expanding foam in it fill every other gap ;):D:D:D:D
Before you try to tweak the door I have found that gently tapping the metal part that the rubber door seal sits on outwards makes the seal fit tighter against the door frame. Might be worth a try first.
looks like a trade mark for the 500 windy doors :D
will have a look at mine on weekend big hammer at the ready that should sort it out :eek::):):):)
no squeekys as yet but cant wait :rolleyes:
