Styling will these fit my punto?
That tyre size is too big - the outer radius is 4.5% too big, which will cause your speedometer to underread and may have arch clearance issues. 215-width may not even fit in the arches anyway.
Figures you need to know for the alloy wheel (ignoring the tyre dimensions) are...
Size: <= 17 inches
Number of studs: 4
Pitch Circle Diameter (PCD): 98mm (although +/- 2mm can be corrected with 'wobbly bolts'
Offset (ET): 35mm (smaller than this CANNOT be corrected, larger can be corrected with spacers
Centre bore size: 59.1mm (smaller than this will require boring by a workshop, larger can be corrected with spigot rings.
For bolts, spacers and spigot rings, PM member 'richie.guy'
Incorrect.
Standard Sporting alloys (not HGT) alloys have an offset of 33mm. HGTs have an offset of 37mm. 35mm is the standard JTD steelie (6x14) offset.
Fiat CB is 58.1.
Incorrect.
Fiat CB is 58.1.
That will explain why HGTs have completely different hub/carrier assemblies. I've heard both 58.1 and 59.1 mm quoted as this centre bore. Since the brembo catalogue lists 59.1mm, that's what I went on.
And then just to confuse things, the Punto Grande is a GM spec :bang:
