Technical Will a 063 battery fit a Panda?
JD82
Established member
Euro car parts have a Bosch 063 silver on offer for £45, the 202 version is £56.
I seem to remember reading in the manual that a 63 type will fit, but will it fit on the existing tray without any modification or will it be a much easier job if I just get a 202 battery?
Measure it. On Europarts each battery will have dimensions in millimetres, amps and cranking power.
If the tray size fits ok, then check height. A little taller is Ok. On amps and cranking power, more is better. I have always liked big beefy batteries. You only appreciate it then in January and February when it is minus 6 degrees.
