General  więcej XDF
General  więcej XDF
peppe500driver
Witam wszystkich przyjaciół na forum, ponieważ jesteś dobrzy, są bardzo zestresowany, że nie może znaleźć XDF pliku dla tunerpro dla Fiat Punto 1.2 8v jednostka IAW 8f, niektórzy z was może mi pomóc lub wie jak je tworzyć? I udało się umieścić jedynie adresy różnych mapach, nie rozumiem numery 250000 i 00000, jak trzeba ustawić te parametri.per proszę, jeśli można mi pomóc map mój punkt widzenia.:slayer::slayer::yum::yum:
Welcome all the friends in the forum, since you are good, they are very stressed out, it can not find XDF file for tunerpro for Fiat Punto 1.2 8v unit IAW 8F, some of you can help me or knows how to create them? I was able to put only addresses the various maps, I do not understand the numbers 250000 and 00000, as you have to set the parametri.per please if you can help me map my point.:slayer::slayer::yum::yum:
English speaking here mate....
Maybe woj can help you.
That is in a way entertaining. The language of the phrase above I guess is triggered by me answering one of the PM's from OP in my native language receiving a message in Italian (seemed like the only reasonable thing to do). Though not distinguishing between PL and EN is a bit worrying if you ask me (though again, the amount of folks from PL living in UK probably make this difference more and more hazy evey day).
Maybe can help you.
Anyhow, I helped all I could, I made a clear statement in my thread on IAW-s about what I will and will not provide. As harsh as this is, I know at least of one forum member that learned his way around IAW-s a bit, because he was motivated by my firm position on things.
Understandable, it is a big part of what you've been working on. So He asked you by PM and you responded, now he's asking again publicly expecting a different answer.
Good luck to him. :D
When you rely on Bing or Google to translate, you can only hope (no chance) it will do a good job with the grammatical structure. :D
No there is not, at least not on the forum, there is one for IAW 16F. I will not provide anything else. If you are in real despair get hold of the ECM 2001 program and see if it can help you, it should have the basic maps for a lot of older IAW-s.
Does it look like this??
Sorry this is a fake I made because I was bored...
Yes, it does. Though I assure you that the person that is the source of this shot does not have the .xdf file either.
is no getting near, if you have one and can give me the file xdf, I am grateful, to help a amico.se do not want to give it to me thank you I will try the same elsewhere.
