why TFTs suck!
why TFTs suck!
Hellcat said:
Bet it doesn't beat a Sony x-black TFT panel. :D
But then again not many things will.
Not many things beat Sonys S**T X-Black coating that's for sure, personally I like something that actually has colour accuracy thanks! Sony made great CRTs, their TFTs however are total poop! But then again you did state that a range of displays were the best, that use varying technologies, without even asking what bias the user wants...
Anyway back on track, Why can't ANY display manu make a TFT that isn't susceptible to insects getting between the backlight & panel?
EDIT: Think I know what you mean, but I wasn't giving an expert, analysed response to a customer focused query. Just joking with another member on the forum.
As for colour accuracy, then you really need a CRT as the phosphorus is the same across the screen therefore gives consistent colour. TFts just can't match the consistency.
Back on topic, I've not seen an insect get into a TFT before. You work in a zoo or something?
Stating a point, various techs give various properties some people prefer one bias some another, as such there is no 'best' display but rather displays which are most suited to a situation. To make such a general statement like that can be counter productive. I probably didn't state that in a 'friendly' manner either (it's too darn hot!)
Yeah totally agree CRTs are the only way to get consistently great colour accuracy, however some LCD panels do a lot better job of colour reproduction than others. Sony's X-Black coating makes the colour reproduction wander in the negative direction
Search the net you'll find people with similar problems, it's not a massive problem but it does effect some.
No problem.. I understand! Which computer is best? Which server is best? Which car is best? Which flat roofing felt adhesive is best? :confused:
I get these questions and more and yes the answer does depend on what you need it for. I only know the x-back we have is pretty good. Someone on here posted some 'white text' for amusement value. Only problem was the background isn't white so I could read it although the anonymous poster couldn't until they viewed it on a CRT! Anyway - Get yourself a nice cold one from the fridge and relax!
StoneNewt said:
Sony's X-Black coating makes the colour reproduction wander in the negative direction. Search the net you'll find people with similar problems, it's not a massive problem but it does effect some.
Unless you have a CRT beside you probably wont notice the difference. Its like selling a HD tv to someone with poor vision.. I can hardly tell the difference between DVD and HD and I've got 20-20 still :cool:
What's your line of work if you don't mind me asking?
If your looking for the best quality picture available (price no issue) then a CRT monitor is still the best. You can't get the black level on a TFT at the moment. Broadcasters rarely if ever use a LCD TFT for grading purposes and will insist on a properly aligned grade 1 CRT monitor. Having said that they cost about £13-14K for a HD versions in 17", so you have to be pretty critical.
Personally for home TV use I would still use a CRT and it won't be until HD has been around for a while and the format is confirmed that I look at a LCD TV.
I've had similar experiences with displays. A lot of people didn't rate my NEC display cause with the out-of-the-box settings it was s**t. But the display was very capable just badly set up, given a few min of tweaking the brightness/contrast it was much better, then a quick eyeball calibration delivered a deep & rich deep. The 'problem' with Sony displays is that they have great default settings, however there is very little room for improvement, a lot of other displays feel worse to begin with but end up better after being properly setup.
*looks at the 7 coke bottles on the desk* ;)
Every X-black display, even after calibration, has lagged behind the same panel without the X-Black coating for reproduction when comparing a 'good' print to what you see on the screen.
I'm a mechanical maintenance by job, however I'm trained A/V tech and have a fair old history in graphics & photography
Okay a new pic of my display, I've highlighted two areas where there are bugs under the panel :(
Who would do such a thing? :confused: What an idiot! :p ;)
H
Thought you might have worked in A/V. My friend worked for a couple of years as a studio tech with the Avids and things. Panasonic he said (the professional stuff, not the tat in the shops) was some of the best a/v equipment about.
Does your panel come with a dead pixel.. I mean dead insect guarantee? I'd love to hear the convo to the tech desk..
Tech> Hello Dell PC tech, how can I help?
You> Hi, I have a panel with two dead bugs.
Tech> You mean dead pixels? We only repair if there is more than 5 sir.
You> No, bugs.. They were moving before they expired.
Tech> Errr.....
*silence*
Tech> One moment please.....
*silence*
Tech>Hello Dell 2nd line support.. How can I help?
Na, you just say you've got # groups of dead pixels.. tech comes out and fixes it... (or that's the plan)
Grrr... my cheap TFT (Samtron?) has also got one of those b***arding little fly things inside it! Is it possible to take the screens apart and remove the fly, without completely wrecking the display? :confused:
yes totally done it before, however it voids your warranty and if you mess it up you've got big problems, oh yeah a sharp tap (no don't hit it as hard as you can) to the top &/or side may dislodge the critter to the bottom of the display.
I just said it had about 15~20 dead pixels & the next day a tech arrives.. Inside 20 min has removed the offending critters from the display
he didn't clean the front of the panel but the back and backlight system.. I did the front... takes about 30s
