Technical whistling noise ???
panda st
hi all any help will be muchly appriciated there is a whistling noise coming from the drivers side of the engine bay cant quite find where any ideas would be great
Referee stuck in the wheel arch? Could be a lot of things. Touch the pulley wheel, if its hot the belts most probably loose or worn causing it to slip.
cambelt tenionser, alternator,inlet manifold, just some to go
:yeahthat:
Disconnect the fan belt and run the engine, if the noise is still there it's likely to be the cambelt tensioner, if it's gone you're looking at a possible alternator bearing or slipping fan belt which can be cured when you refit it of course.
