General which sensor?
hayley202
kent
Hello, been trying to get a lambda sensor for my bravo 1.2 16v (2000) apparently my car has more than one sensor and when i rang a fiat dealer, they wouldnt tell me! (They proberbly knew i would get one cheaper elsewhere!) Does anyone have any ideas as its due its MOT soon and i need to sort the starting trouble out.
it depends on your engine. you need to look at the engine code on the vin plate. you should have
-188A5.000
or
-182B2.000
also you can check your ecu it will be
Bosch Motronic ME7.3H4 (for 188 engine)
or
Bosch Motronic M1.5.5 (for 182 engine)
give the supplier your engine number, and then if your engine has 2 lambdas listed make sure you order the regulating sensor (front one).
you dont need a diagnostic sensor (rear) because when that is faulty the only problem is the engine management light, everything else works perfectly.
Yeah, not only are my emissions running high but if they turn the engine off it's 95% certain of not starting again :bang:
