Hi im topping up my engine oil and i was given multigrade Chevron supreme SAE 15w-40 by a local car parts shop just wonder if this is correct if not what should it be?
thanX
mykeie
As RobW said, the best is to go with the oil that Fiat recomends and that is SELENIA K PURE ENERGY.
Also you can go with SELENIA StAR PURE ENERGY (it has exactly the same specifications as K P.E, only it is advertised for Alfa Romeo).
Just pay attention to this PURE ENERGY, because you have also regular SELENIA K and SELENIA StAR (without PURE ENERGY) and those are not recomended oils for Bravo.
If you actually read the user manual it says to use anything meeting these minimum specs. Since nobody sells Selenia I am sure its a dealer money making scam!
As I am new to Fiat ownership I don't know what Fiat insists on, but a lot of motor manufacturers now require you to use only recommended oil. I know that all VW and Ford warranties require that only approved oil is used or it invalidates the warranty. If your car is out of warranty then it doesn't matter.
5w 40 5w 50Hi im topping up my engine oil and i was given multigrade Chevron supreme SAE 15w-40 by a local car parts shop just wonder if this is correct if not what should it be?
thanX
mykeie
