Technical which engine is this
it says punto s at the back, but this isnt 55 engine
attachment.php
I'll admit i didn't look hard at the pic - just know i ain't seen that engine before lol.
Its really hard to say with the airbox on it but looking at it now I lean towards the 1.4 12v engine as found in bravo/a - never seen or heard of one being in a punto but one would drop in pretty easy i would suspect.
again, it doesn't look quite right but the dizzy thing with ht leads on looks bang on the same, and the 3 bolt pattern for the throttle body is the same layout and position as the 1.4 12v, the leads go to where the plugs are located on the 1.4 12v - think thats enough proof
you're not wrong actually - thats not a punto slam panel - didn't even look at that.
the 3 bolts/studs holding airfilter to carb / throttle body is oldskool ,
like the 903 engines,;)
possible the 1100 tipo..?? :confused:
I had 1.4 tipo's - the PAS pot and electrics all look tipo..but I don't recall that engine of filer box..:eek:
EDIT - it's a single coil..!! and has PAS so may well be a 1600cc
