Yes you could say voltage doesn't mean much if it hasn't got the amps to back it up. Power =V x I and all that stuff. The alternator voltage regulator can be doing it's best to maintain steady voltage but without sufficent current it can't supply the umph to power everything. Steely's doesn't even pass the static tests
A current induction clamp is better for other reasons too, when you disconnect the battery you reset the ecu so it loses all its refined fuel trims etc. But they're not very accurate if you're looking for less than 1amp as in a current drain as they will often measure up to 600amps
Thing to watch if you're doing power off current drain checks using the induction clamp is that the Stilo, like many newer cars, latches on and keeps a lot of circuits live for some considerable time after turning off the ignition. Even waiting an hour you'd think would be enough but when you do something like open the door then a lot of circuits become live again. Ha! Back to square one
