Technical where are the relays for the Frontfans?
dajon
germany
Hello everyone,
Does anyone know where the relays for the Frontfans are located?
Background:
I’m increasingly getting the following fault codes:
Code – Meaning
P0693 – Fan motor 2 – circuit low
P0691 – Fan motor 1 – circuit low
U1400 – Invalid or missing signal from a control unit (CAN communication)
P0495 – Fan running at too high speed
P2291 – Injection pressure too low during start
I would be really grateful for help, have been some hours on the problem...
Model
270 HSN/TSN: 4136 / ATC00002 94 kW
2014
Mileage
405000
Here a Picture - where in the car is it?
WOW, thanks! I found them! All the help i dreamed of!!
I used An obd bluetooth device and "Car SCanner" on android. I also have similiar error codes on Diagbox. Could you look for this operation on the picture?
the Relays are directly before your nose in a black box, when you open the car....
In the end it was a corroded little red cable in that massive braid of cables.
