General  Wheel squeaking
Bessboo06
Hello ! I have a front passenger side wheel that is squeaking , I checked the disk and pads h the today , the disk looks fine and is coming up a 10.5 mm (it’s min is 9.1mm) . Brake pad thickness was around 7mm . I did notice it dragging some dust as it was going round ? Also when I press the brakes the sound goes away , it’s a really annoying squeaking!! Any insight would be appreciated thank you
There is a slide pin which has been mentioned.
The slot at the lower end of the caliper casting (that the retaining pin passes through) swells with rust causing the caliper to bind on the retaining pin. This can cause drag and uneven pad wear. This is very often overlooked.
Some pads are more squeaky than others.
Some pads have plain metal backing plates, others have a rubber type isolator stuck on the backing plate, some people swear by anti squeal paste applied to back of pads.
Thanks everyone , I’m going to get wheel off again tomorrow and have a good look
Check the caliper slides easily on its pins? Check the pads are not bar tight in the caliper bracket
Are the pads supposed to be touching the disk while I’m not pressing brakes ? Mine was tight on disk , I could move disk but it was a little tough
I can wire brush that ? Are you talking about the pin which you attach the little pin from brake pads set to ?
Yes the pin that has a retaining back up spring clip.
You can wire brush but if caliper slot very rusty it may need scraping out more firmly than wire brush can manage.
Frowned on now, but copper grease on the back of the pads can help. (copper grease anywhere near the brakes is apparantly bad now, though most have had no issue with it for the last 50+ years)
BMW claim copper grease does no end of damage to their brakes, and you must only use BMW approved grease.
