Technical  Wheel nut torque settings
PeterM
Black Rock VIC
I know the Ducato does not use wheel nuts, but what do you call them? Wheel bolts?
Whatever. What is the specified torque for doing these up?
Thanks and Happy Christmas.
Hi Peter
- For the 10 and 15 versions, tighten the wheel bolts to the recommended torque.
Value - 16daNm M14 Bolts (160Nm)
For the 18 version, tighten the wheel bolts to the recommended torque.
Value - 18daNm M16 Bolts (180Nm)
Procedure:
Fit the wheel & secure it without tightening the bolts.
- Lower the vehicle, then tighten bolts to specified torque
As per standard practice the bolts should be tightened in a diagonal sequence so as not to warp the disc.
