Leighton88
- Joined
- Oct 6, 2009
- Messages
- 3
- Points
- 1
ive recently had my sump tank replaced due to a hole. and now my car is over heating when i drive it roughly 10 miles or so. checked my water and that is fine, the oil is ok. when it overheats, i pull over and check the engine and the weird thing is the engine isnt even hot. theres no hot air coming through my vents at all. no leaks, no steam. i topped the oil up today but it didnt show on the dipstick so bit confused as to why that is.
has ne1 got ne ideas as to what it could be? i got a feeling it could be the sensor to the temperature gauge cos its going over the mid heat mark but the engine isnt hot. or it could be a clog in the pipes, or the thermostat could be jammed which is holding the valve which releases the heat into the cabin closed which is causing the hot air to build up pressure through the pipes. has nebody had this problem or similar problems?
would appretiate ne help u can give me
thanks
thanks
