Technical What should i have done why headgasket bein done??
Derby
My cars in for headgasket this week, 16vt. should i get CAM belt done, also i was thinking maybe do the water pump and thermostat. Is there anything else worth doing why its at garage???
the cam belt must be done. only a retarded catfish would refit a used belt. the timing belt tensioner should be changed too.
water pump is up to you, but its a good idea to do it now when it will only cost a very small amount extra.
thermostat is easy to replace and not affected by belt so there is no need to replace it unless it is faulty.
