Technical  What is this light for? Window pressing button issue..
StanZlatan
Hi guys. My car fiat panda 2014 hatchback petrol has developed an issue with the button opening and closing the driver side window. There is no issue with passanger window. I attach image of the light and will try to upload video. Basically when window closes sometimes after i continue to press the button to close this light comes on. During this fault issue also the window does not automatically close as it would otherwise. This thing happens only when car is turned off and you can usually close the window after you turn off car. But now in 40 percent of time i feel like if car is tilted the window stops closing and after it stops this light comes on....
The dark light with the sitting man with crossed airbag or ball and the number 2. On video it also lights as i press the close widnwo driver side button
  • VID-20241002-WA0003.mp4
    1.9 MB
That light is showing a fault with the passenger airbag. But i suspect the issue is actually a failing main battery if it only happens when the engine is off. The electric windows use quite a lot of current. It could also be showing that the wires from the car into the door are damaged. Someone else posted a similar comment before
Ok so i have replaced the main battery the other day because such problem has occured 2 years ago and that fixed it. Now no. So ....i guess i have to check the wires. This is horrible
Or your alternator is not charging the new battery??
I dont think so because then the sighn of not charging battery appears. And my dashboard is clean. Also this problem appears when car is off. I think it appears if car is tilted as now it solved itself for some days now....
