General What does this mean?
zhguxi
United Kingdom.
Normally, turn the key on, the indicator light of battery will be on, start the engine, the light will go out
However, this is not always ture in my little UNO-- Sometimes, the light dose not light when I turn the key on.
Does anyone know what this mean?
Maybe a false contact of the lamp inside the panel!?
Do I turn fast enough!?
most likely a dodgy bulb as enzo said but if not it could be an alternater fault.have a look at the bulb ASAP as it is part of the charging circuit and if it is faulty then the battery wont be charging
A Dog Is Not Just For Christmas
Sliced Thinly It Can Last Till Easter
its the warning that your aulternator (spelling) is packing up.
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
I had the exact same problem. If the light dose not light when you turn the key on the alternator will not charge! A small current (the present of it is shown by the light) is necessary for the alternator to begin charging!
Check that the thin wire (grey/black?) between the panel and the alternator is ok. Mine were broken just were it is attached to the alternator, which were hard to see. Sometimes there was a connection sometimes not, after a couple of months my battery was flat. I was recommended to change the alternator when it was the grey/black wire all the time. Good luck!
DO NOT REPLACE THE ALTERNATOR!
