Technical What carb do I have? I believe its a DICA but mine seems to have an extra tube.
toomanynuggets
Fort collins
Model
850 sport spider
1973
Mileage
80880
Specifically in the bottom picture there seems to be an additional unit with a hose coming off of that I haven't seen in other weber 30 DICA's. I'm looking for a carb rebuild kit and would like to know for certain which carb I have before ordering. Thanks for any help!
It's a 30dic11 from a 903cc sport spider and correct for your car as it has some smog control stuff on it. It has choke of size 23/23 but most repair kits cover all the 30dic models, check your primary shaft play as you've got 80k miles if the pivot is worn it may create a variable idle if you have a worn shaft.
Tim
Hi, new to the forum and working out my own carb issues on my 70' 850 coupe. Just went through my carb and I think I have the same setup as you. Currently trying to work out what emissions stuff I can circumvent. Can you tell me where the hose circled in red below goes? On mine, this port was open, I felt a vacuum on it so I put a rubber cap.
