what blooming spark plugs do i use?
Doesnt it depend on the ECU in use dave? Thinking of the ECU electrical output load it prefers really. No size difference I assume, main thing obviously is dont use any plugs that are physically longer....
i dunno thats why i did a thread :p ive probably been told it before but have forgot :eek:
Seen a Post or two on here about failed Punto ECU's where wrong impedence plugs were used and the ECU didnt like it at all. I'd go with what was OE for the standard engine personally, but new ones, that way your OK with the ECU and the plug length into the head so no piston to plug fouling.
http://www.ngksparkplugs.com/techinfo/spark_plugs/overviewp4.asp?nav=31000&country=US
from [url said:
http://www.ngksparkplugs.com/techinfo/spark_plugs/overviewp3.asp?nav=31000&country=US][/url]
Keep in mind the insulator nose length is a determining factor in the heat range of a spark plug, the longer the insulator nose, the less heat is absorbed, and the further the heat must travel into the cylinder head water jackets. This means the plug has a higher internal temperature, and is said to be a hot plug. A hot spark plug maintains a higher internal operating temperature to burn off oil and carbon deposits, and has no relationship to spark quality or intensity.
Conversely, a cold spark plug has a shorter insulator nose and absorbs more combustion chamber heat. This heat travels a shorter distance, and allows the plug to operate at a lower internal temperature. A colder heat range is necessary when the engine is modified for performance, subjected to heavy loads, or is run at a high rpm for a significant period of time. Colder spark plugs remove heat quicker, reducing the chance of pre-ignition/detonation. Failure to use a cooler heat range in a modified application can lead to spark plug failure and severe engine damage.
:confused: says some thing in that link about Higher Compression Ratios too, i think the gp is higher than the punto?
I'd be inclined to use the plug for a 1.4 16V engine dcpr7e-n-10.
In fact that plug I find was designed for Fiat and is used in more than one engine.
Make Model Engine Date EngType PartNumber Quantity Notes
FIAT PUNTO 3 (07/03-->12/05) 1.2 10/04-->12/05 DCPR7E-N-10 4 8 VALVE
FIAT PUNTO 3 (07/03-->12/05) 1.2 02/05-->12/05 DCPR7E-N-10 4 16 VALVE
FIAT PUNTO 3 (07/03-->12/05) 1.4 11/04-->12/05 DCPR7E-N-10 4 16 VALVE
The Grande plug will possible be because it uses the variator to get over its higher load on engine due to higher kerb weight meaning higher emissions which the variator is used to return to levels of lighter cars.
And ss you put the head on and removed the GP head the compression ratio may have changed but I think all the SuperFIRE engines are in region of 11:1 or at least 10.5.
We just used standard plugs that came fitted on our Sei 1.4 16V (Stilo) engine and that runs wasted spark and Cento twin coil packs with no problem. Though I can't remember but may have fitted new plugs at last service and just used what we found on shelf at Halfords again no issues.
the gap in gp ones is preset an looked massive, i had slight missfire so had to buy plugs, i bought 1.2 16v ones because if they turn out crap i can put them in mrs daves car, they are about 2mm shorter than the gp ones. missfire cured, it was only missing when reved though not on tick over
i put this engine in at 75k miles it now on 89k miles, i didnt think i been that for :eek:
