Guys i need your input i have this strange problem. WHile only in 4th gear ( not in any of the others) sometimes under steady rpm clibm, accelerating around 4,000 rpms it seems like the rpms jump about 500 rpms faster than the steady climb and then drop down a bit and then continues the rpm climb.
Its very strange. i dont believe its a clutch problem (but im not sure ive never happened to come upon this problem to have real life problem to acknowledge the symptoms) I changed the clutch when i chagned my gear box this summer. i did the classic test for clutch problem, handbreak up 1st gear and drop the clutch to see if the engine stops right away. Also same way but instead of dropping the clutch i gradually dropped it to see an incrrease in rpm but nada.
ITs very strange i did notice i leak a bit of oil from the crankshaft but i dont think it would leak to the clutch plate since its behind it would it?
