Technical Weber DMTE 30/32 to Fiat uno 999 mk1
chesh
Established member
Hi all,
I've installed a Weber DMTE 30/32 on my 45 999 Uno instead the single carb, Punto 75 866 Camshaft + electrical fuel pump.
I am missing this unit (picture), Looks like someone took it off the bolts.
So I stay with just the output pipe which I don't know what to connect or block it. I don't know what it's purpose.
first run, everything was ok but it had a problem of going up to 2000 rpm and back to normal idle every 20 seconds.
I took the carburetor apart, cleaned it all and renew all gaskets + rubbers.
When starting the car now, engine revs to the limit without stop so I need to turn it off.
both butterflys of the carb working and it's not open on idle (even when accelerator cable is not attached).
There are 2 more electrical wires goes from the carb which are not connected to anything and I don't know what they do.
Anyone ever fitted this carb to 999 engine and can tell me what to connect to?
Also on the distributor, there's a diaphragm that I need to connect it's vacuum hose to somewhere? I guess on the back of the carb?
Problem solved!
it seems that this acceleration pump was touching the adapter plate, and couldn't return to it's place.
What for is the vacuumhose in the bottom. I bought mine uno and it isnt going anywhere. But when i fill it,car dies..
