Technical Water leak near the thermostat
chesh
Established member
I've changed the thermostat gasket and noticed this weird water leak:
it only leak like 2-3 water drops after I turn off the engine.
I didn't see that leak until I changed the gasket.
where is the water coming from? as I can see, that hole is leading nowhere and closed from inside.
Youre also missing the rubber cover for the clutch inspection hole! If anything drops in there then at means sperating the engine and box to get it out!
yes I know, where can I get that plastic part?
Nobody has that part around here.
part number would be great if you know it, also couldn't find any on ebay.
Believe they are the same on most fiats from the nineties so might be worth looking on other fiats in the scrappys.
Have you brought this? If not I might be able to get you one for less than postage.
I found it the other day at local fiat dealer here for 3 pounds.
thanks for the help!
