wat does twin cam mean
K
kev
wat does twin cam mean.is it good or bad and wat does it do....thanks
Twin cam as the name suggests, has two camshafts....
Basically it uses one cam for the inlet valves and one for the exhaust valves...
It's a good thing, why do you ask?
Daz
i asked because im looking at a 1.8(115)hlx or a (155)hgt..and i heard these are twin cam..but can u tell me if they are if u know better..thanks
You are correct they are both twin cam, the 115 and the 155 are both DOHC (Double Over Head Cam), but the 155 has VVT (Variable Valve Timing)...which in theory improves things moreso...
Daz
having two cams isnt necessarily better than having one.
low end torque is none existent in these type of vehicles.
Twin cam > single cam
speaking of cams, i fixed the camshaft on my brava today, never seen one so badly worn
Got a new one, all new service bits too.. it was poorley looked after with the previous owner
Lots of short runs is also a cause of that, not the worlds best design...
its an old design compared to the other bravo's isn't it? I heard it was the same engine as the older Tipo's.
Tom, would being worn make a ticker,ticker,ticker noise?
A
3
699
Ant Wells
A
G
585
garaint
G
S
11
519
A
