Next job after fixing my wipers is the washers! Thought i just needed water! Added that and still nothing.
Can't hear pump so I replaced it and still nothing wipers move just no jets of water. Looked under bonnet in fuse box manual tells me its F3 for the fuse however I can't seem to locate F3! :/ All the 10 amp fuses I checked have not blown either! - It's either NOT there at all or someone has replaced it with a 15 or 20amp at some other point in the van's life.
Are the fuses under the terminal connections? As I can't work out which is which, the numbers on the flastic which are molded I can bearly read and no diagram under the fuse lid or in the booklet with a map to the fuse.
Few things to note the funnel that goes to my water tank is missing (i think its always been missing since i had the van)
They where working then stopped BEFORE the wipers died just living in wales I don't need the extra water
BUT i think the MOT guy does
New pump fitted wires seemed fine, water ran out of tank so no blockages couldnt see any obvious blockages either in the line when i pressed it.
Wires all seem OK. Hence why i think it must be a fuse.
