S
Fiorino (Mk3) (Wanted) Wanted front mat and the padding from underneath the mat
Type
Wanted
Expires
It's well worth asking a Fiat dealers parts department (based on your VIN and description) whether they are still available (new)
Not sure on your year but you can look yourself (up to about 2014) https://eper.fiatforum.com/ , select commercial and then Fiorino and then the appropriate model year, the mats are located under internal trim.
If your vehicle is less than 2014 you can put your VIN in to narrow down to parts that are purely fitted to your vehicle.
thank you i will look there, also you made me aware of information lacking in the post, i have edited it to say its a 2013 model - just , registered 30th December 2013.
Then your VIN should be recognised by the free (only valid to about 2014) version of Eper here on Fiatforum.
Then navigate to the internal trims and you'll get the part numbers, then you can go googling or direct to a dealer to see if the parts are still live and orderable.
Hi thank you for your advice, i researched cleaning up brake fluid, apparently it washes easily with soap and water, and it has , after a good wash and dry in the recent sun it has come up almost as good as new, again thank you for you help and advice, i need to make a new post asking about the fluid, looks like it may be from the clutch cylinder and not as thought from a spilled can.
