kvonk
- Joined
- Jul 29, 2009
- Messages
- 97
- Points
- 36
i buyd a 1.4 16v engine with a low millage ( 82.000 KM )
i will rebuilt the engine:
the crankshaft will lost around 1kg
the flywheel will lost weight around 1.5kg
and crankshaft pully will lost some weight
and the 3 upper parts will bold on each other and get balanced to 0.5grams
the in and outtake will be bigger and so smooth as possible
the rods and pistons will lost weight and getting the same weight
and i will feed the engine with a 4x42mm itb from a bmw 1300 motorcycle
the spark plugs will be from denso (iridium)
the exhaust will be the same as what if made bij my self:
supersprint - bravo 1600 kat - cch 48mm pipe and a endbox from a motorcycle
and a standlone ecu
and a standlone ecu
