Technical Victoria's Ill - 750L Running Issues
You did say money no object Jon ;). How much are they?
Nearly £170, plus the coil as the coil is different for them iirc.
http://www.ricambio.co.uk/904-electronic-distributor-complete--classic-fiat-panda-uno
I was expecting about £100-£120 all in.
My friend said he would expect about £40-£50 for most basic setups, and £100ish for all singing - but he's more at home with land rovers, and I know bits for them are often easier to get.
Seen this, but think its only the inners.
http://www.ricambio.co.uk/1035-distributor-electronic-pick-up--classic-fiat-panda-uno--lancia-y10
Just purchased a Distributor setup
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300777446780#ht_500wt_1413
and coil
http://www.ebay.co.uk/itm/300775415...NX:IT&_trksid=p3984.m1439.l2649#ht_500wt_1413
Should work nicly all being well.
Is there anything I'm going to require loom wise for this setup from the donor motor? I can't remember the setup to well on our 1000CL - Just so I acn see if the seller can chop the bits of loom from the donor car and include them within the sale.
You'd be better off if they could supply the piece of loom that goes from the coil to the connector on the distributor. There is also a wire in this piece of loom that goes through the dash and is the ign. feed, they can cut that off and you can join it to your ign. feed.
P.S. Not sure that's the right coil Jon, can't see any spade connectors.
I did email the seller before hand, and he advised me it is the correct coil, so I'm not to sure. Will see when it arrives....
Still waiting to hear about the loom pieces.
Failing that I'll be on the hunt for someone breaking one. Never know with all the looms I've got, might be a plug that I can hack to fit :eek:
