Basically i have installed an ipod dock into my stilo, it has a line out for aux cable and a ipod cable port for charging, when i first used it it sounded like it should, but i went to use it yesterday and it sounded terrible ( imagine you film a video on your phone in a night club and play it back the next day and you can't hear anything because the phone speaker can't handle the loudness of the music in the club and it sounds distorted ) basically thats the sound i'm getting, It's mostly the bass that is distorted but the highs do seem a little distorted from what i can tell but...
if i take the dock out the the equation, and connect the ipod straight to the HU via aux cable it sounds fine, also the same when using a CD, i wouldn't say it was the dock that was playing up because i have to identical docks, both brought at the same time, and have tested both, one of them i have fiber glassed into the car.
So i did some trial and error, i tested 2 different aux cables, both work fine connected straight to the ipod, but not through the dock.
Tested using the front and rear aux input on the HU, works fine with aux, but through dock is bad,
Tested not plugging in the ipod charger and just plugging in the aux into the dock, in both front and rear input on HU, still the same,
Tested using a different ipod cable in dock, same result,
Tested using a different usb cigarette charger, in different cigarette lighters, again, same result,
Tested a different ipod in both docks and just using aux cable, same outcome,
Due to fitting the ipod dock where my hazard light button was, i have had to relocate the button elsewhere in the car, not that i think this has anything to do with it, but just thought i'd mention, and also i have wired a 2nd cigarette lighter from the original one, but have been using that to charge things for a year or 2 so i doubt that would be the case, i was edging towards something to do with a bad ground but i could be completely wrong, but what other option is there? this has really got me in a pickle, and a little p*ssed off because after spending so much time fiber glassing the dock in, it stops working properly, and just to mention, i was using the dock before i installed it permanently, then i installed the new hazard light button, then put everything back together, so it would look like it has something to do with the new button, but i dont see how?
so if you've go any thoughts then please let me know, i think i have covered everything i have done with the trial and error but may have forgotten something, but yeah, if anyone can help i would be very grateful, thanks
