- Joined
- May 10, 2007
- Messages
- 101
- Points
- 76
Hi Mike, I guess you've done this already, but thoroughly check all the vacuum pipes for splits or holes. I had the same error code, and together with thoroughly cleaning and lubricating the solenoid with carb cleaner, and checking the red pipe particularly, I found a tiny split where it is pushed onto the solenoid. Cutting off the end inch or so and reattaching solved the problem for me. HTH
