using spray lacquer/clear coat
derby
Ive got a bubble in the lacquer on my new bonnet! which leaves a hole about 2cm wide. Just wondered when using spray lacquer can i jus spray the area which is not covered? or does the whole bonnet need re spraying?
Re: using spray lacquer
You might have to do the whole bonnet - when spraying I was always told to do the entire panel (or will look patchy and crap as it wont blend)
