okay i bought one of these
http://cgi.ebay.co.uk/ws/eBayISAPI....MEWA:IT&viewitem=&item=230109274188&rd=1&rd=1
now under XP it states no driver required and its plug n play.obviously not for me
using my spare 3.5" IDE hard drives it did install but showed an error on install.
it then flashed up this device can perform faster connected ot a USB2 port.
however all my ports are USB2.
its a new nforce 4 mobo running on xp pro SP 2.
also tried a spare DVD drive which powered up but didnt show on my computer
ive tried it on a few USB ports as i thought it was my front ports but even directly to the motherboard its the same.
ports work for everything else.
hard drive powers up but doesnt show in my computer.
ive tried CS,master and slave jumper settings.
dunno what info you need or whether its just a faulty unit.
so if you need me to give any info ask away
edit: it just flashed up the usb2 message even though the drive isnt connected
Features:
Quickly access SATA / IDE 3.5" (40-pin) / IDE 2.5" (44-pin) device by USB port
Support hard drive, CR-ROM, DVD-ROM, CD-RW, DVD-RW
Support 52x CD-ROM
Compliant with SATA 1.0a Electrical Specifications
Compliant with USB2.0 Electrical Specifications
Compliant with Bulk-Only Transport Specifications
Compliant with USB Mass Storage Class
Support ATA/ATAI LBA 48bit addressing mode
Support SATA spread-spectrum transmitter
Support SATAI Asynchronous Notification (Hot Plug) feature
Support 480Mbps High Speed and 12Mbps Full Speed USB operation
Come with power supply adapter
Power input: 100~240VAC, 50/60Hz, 2A
Power output: 12V, 2A and 5V, 2A
System Requirements:
One available USB port
Microsoft® Windows® 98se/Me/2000/XP
64MB RAM (96MB recommended)
Package Contents:
1 x USB 2.0 to SATA / IDE Adapter Cable
1 x Driver CD
1 x Power Adapter (100~240VAC)
1 x Power Cord (UK 3 Pin Lead)
1 x SATA 50cm Data Cable
1 x SATA Power Adapter Cable
1 x English Menu
