Communicator
Prominent member
- Joined
- Aug 3, 2019
- Messages
- 3,494
- Points
- 954
So, finally some good news.
The fuel pump not priming was indeed due to the inertia switch being activated. Below is how I found it initially, just dangling downwards at the back.
Also, notice the broken mount on the switch.
I mounted it securely at an upright position, clicked the button back to place and... lo and behold, the fuel pump was back to work happily.
Good news indeed.
But it gets even better: I managed to fix the central locking system! After wiring back the unit and supplying 12v and earth, it all came back to life.
Yes, more good news.
Now, I think I will just get a remote fob to control the locks and call it a day.
If not already done, you will have to refit the Cobra unit, or replace with a Fiat alarm unit and receiver + Fiat key fobs, which could be expensive, and difficult to install. See link.
http://4cardata.info/elearn/244/2/244000001/244000003/244000005/244002006
Comm, I did check the alternator on several occasions and it is showing around 14.3 to 14.4v on tick over.
Noted. I do not recall this being mentioned previously.
