URGENT HELP NEED PLEASE
A
alan
Hi all
Am in serious difficulty,
Got my car serviced by my local (non fiat) mechanic. he disconnected some lead, now the code is gone. He tried to start it a few times with the blue key but it kept cutting out.
I got the red key and tried it but wont start at all.
Have not got the emergency start code either.
What can be done????????
Do i have a serious ecu problem or something that's going to rob me blind.
i am miles from a fiat dealership.............help
hi think you have a similar problem to mine, when u go to start the car does the keycode light stay on ?
to start mine i have to disconnect the big block that goes into the immobiliser its under the steering wheel behind the fuse box. i have to disconnect that wait about 10 seconds plug it back in and then when u turn the key turn it right round to start the car straight away without turning turning to the first position then to ignition, dunno if u will understand but its hard to explain. sometimes it works for ages without resetting the immobiliser but other rimes i need to do it everytime the car stops
Re: Re: URGENT HELP NEED PLEASE
Cheers,
Do you use the red or blue key, have you had this checked out by a fiat dealer and if so what's the problem
A
5
640
M
G
583
garaint
G
B
2
541
Tommy K
T
