I currently use greenstuff pads on originals discs, they are ok, but the discs seem to boil just doing normal driving.
I'm not sure what you mean here? How can the disks "boil"?
Do you mean the brake fluid is boiling "doing normal driving". That is a possibility, but if you're fluid is boiling then something is wrong with your car. Only under very unusual circumstances or when racing should you notice any brake problems of any kind. Certainly, a stock modern braking system should perform perfectly "doing normal driving".
You can't expect significantly more stopping power than what you already have by simply putting on larger brakes, if what you're looking for is the ability to bring the car to a halt in a shorter distance. It is true that under racing conditions a standard braking system will usually exhibit fade but any standard system will lock the brakes without ABS or be able to operate at the ABS limit for at least one maximum performance stop and most systems can do way better than that. Even when racing, step one to improving brake performance is usually centered around improving cooling before resorting to larger brakes, depending of course on the class rules.
Racers like a brake pad with a lot of initial grip and good pedal feel. The idea is that you want to go from zero braking to max performance in the shortest possible time and hold the brakes on just at the threshold of the available grip. You want a firm pedal and a pad which will give you good feed-back. A "racing" pad will give you that and marginally improve braking performance but often at the expense of noise, disk wear, dust production, and cost. Changing to braided lines will also slightly improve the brake feel and therefore offer a tiny bit better ability to instantly go right to the threshold of available grip and stay there, but none of this is really necessary for street driving.
Typically, changing tires is going to do a lot more for reducing stopping distance that will changing brakes. Back when I used to do some racing, I normally put street legal racing tires on my daily driver. The difference in performance was dramatic, but the stock brakes were just fine after changing to Performance Friction carbon pads. Of course, tire wear was horrible and if it rained, traction was equally horrible. But in the dry, it was lots of fun.
Stiffer springs and better dampers are another way to improve your car for not too much money. You'll get a lot more bang for the buck with springs and dampers than bolting on larger brakes.
I live in Italy in a place blessed with wonderful twisty roads. There are plenty of places with little traffic and the policemen are a lot more interested in checking ducumentation than enforcing speed limits. Plus, most Italians seem to like driving fast and the ones who go slowly don't seem to resent those of us who enjoy spirited driving. When the mood strikes and the conditions are right, I push my cars harder than most, but not for sustained periods because sooner or later you come upon a town, a potentially dangerous intersection, or what have you. In other words, even slightly crazy open road driving ain't racing. I have yet to wish for better brakes. Better tires, smoother pavement, more horsepower?.......... yes, but not better brakes on any car which could be considered even mildly sporting.
Like I said before, if you want to enjoy "track days", then you may want to do something about your brakes. But there's plenty of performance improvements to be had in other areas for a lot less money.
