Technical  Rusty brake disc on one side?
It's not difficult. You can also put new breaking fluid in, whilst you're on it. If you want to keep the fluid, you can put a sort of cork on the pipe after you disconnect it from the caliper then after reconnecting it you do the bleeding.
New does sound better, most of the times. But you can decide if the ones you have are worth keeping and if you can improve their state, after taking a closer look at them.
I might take the rubber on the slider pins off and see if i can live with the noise! I don't have much to lose as I would have to buy new ones to fix this anyway.
I was a bit nervous about pressing the brake to extend the piston, i have bad memories around killing rear wheel brake cylinders lol. So i didn't extend the piston much, but i think i'll have to do that and get a wire brush/scrubber on them.
I bled one of the front brakes to see what the fluid looked like and it was dark and grimey, not the worst, but i'll have to change all of the brake fluid as soon as practical.
Better than wire brush, you can use scuff pads and brake cleaner.
Thats a good idea. I was possibly going to scratch them into failure.
I don't think you'll get much noise from removing the rubber. It's role there is to prevent dust going inside and to contain the grease on the slider.
OK, thanks, thats now the first port of call.
I returned to this today.
I took off the sliders, removed their rubbers completely and left them off the car. I greased the sliders and put them back on. The calipers were moving freely. I then bled the brakes.
But it didn't make a difference.
I suppose I'm trying to avoid cleaning the piston or replacing the calipers.
Would cleaning the clips make a difference?
I cleaned the hole into which the sliders go, and the sliders themselves, but that was it.
The pads looked flush but maybe they were at a slight tilt I couldn't see. It won't be difficult to clean the clips.
I presume I can't clean the piston properly without taking it off the car?
I cleaned the clips and bracket, I had a lot of trouble getting the pads back in, previously they might not have been flush to the disc. I then drove the car and the discs seem to have been scratched flatter. These are some before and after pictures of the disc.
This is what you get with lack of preventive maintenance (just reactive, "fire fighting").
To identify a problem, you need to clean the parts, a lot of rust everywhere. Sanding/grinding, sand blasting etc. Inspection of the parts: critical features, if the flat surfaces are still flat, right angles 90 deg., sizes, shapes, you know. Outside/external features. Then internals (yes, pop the pistons out of the cylinders/calipers) if dealing with external stuff will not help. Or actually, there is simple test: you pump the brake a bit, then push back the piston bare hands (if it's healthy it must go in - like in a video mentioned below).
Example video, addressing what's outside only (non-english), LINK. But the pistons were retracted bare hand (so they're probably good for now). For example areas where you put the brake pads are 18 mm wide (without those stainless steel sheet sliding inserts or whatever you call it). Sliding pins are "10 mm" (sliding fit, so 9,9x mm). Things like that. If there is too much wear somewhere, the mechanism like that will seize (too little and too much clearance/play is equally bad for moving parts).
Looking at the second photo I'd say some serious derusting is required. I'd sand blast it...
And for the disc, it needs at least some work on a lathe, or any other improvised treatment to make the surface totally rust free, clean and FLAT!
Example video, addressing what's outside only (non-english), LINK. For example areas where you put the brake pads are 18 mm wide (without those stainless steel sheet sliding inserts or whatever you call it). Sliding pins are "10 mm" (sliding fit, so 9,9x mm). Things like that. If there is too much wear somewhere, the mechanism like that will seize (too little and too much clearance/play is equally bad for moving parts).
Thats a very thorough brake job. It was interesting to see the measurements. I might get some micrometers and do the same myself. I used a sanding machine on the clips and brackets, but could do more.
I might take it off and sand it. I realise its not optimal...at least i've found the problem and don't need to buy new calipers.
I took the bracket off today, cleaned it completely with a sander, the clips were cleaned, the sliders are still working. The brake has been fully serviced now and its still faulty. So i've just ordered a new caliper. Its the only thing left apart from maybe a blocked hose, that could be causing the problem.
I've not changed a caliper before, so this could be messy lol.
Any advice?
looking at those pictures though out the thread that is a very crusty car, the slide pins definitely should have been replaced at the very least. I however would say a replacement caliper might be the most sensible option. Make sure you get your service exchange on the old one, and when buying calipers its always best to go for a more expensive quality part then the cheapest part.
looking at how crusty the car is, you may be lucky to get the brake hose out of the caliper without sheering it off.
I would be spraying on the penetrating fluid now in preparation.
I wish I'd remembered this before buying, ahhh. What I do remember thinking is that this part looks aluminium, which isn't as strong as steel. I'll have to decide whether to use it when I have it in my hands. It was the cheapest option but it shipped from Amazon so returns are easy if necessary.
I was planning on a quick caliper switch to avoid excess leakage, but now I'm thinking I'm going to have to stop the flow. I'm somewhat set against the clamps because they might break the hose too.
What do you suggest?
I'll do that asap.
The new caliper has arrived. It was £37, the cheapest on ebay are around £50, and from GSF, £120. It isn't aluminium but a painted steel, or maybe stainless steel, i'm not sure. I'm suspicious about the low price but currently can't see anything wrong with it.
I'm tempted to have a go at getting it on tomorrow, but i really should buy some hose clamps just in case there's a hose breakage and leak that I can't stop. I had a look at the master cylinder to see if i could find the hole which I would then bung up to hopefully stop drips, but it was nowhere to be seen. I could put a crisp packet over it and hope for the best.
I saw a youtube video where the guy used the black rubber bung that was protecting the hose inlet as a stop for the actual hose on the car. I'm not sure if that'll work or not, but its pre-supposing i can actually get the hose off without it breaking.
That has all the hallmarks of a very cheap Chinese knock off. Use with caution.
There is a saying in medicine which is “all bleeding stops…. Eventually”
You can just put the ends of the pipe into a plastic bottle. I normally do that rather than clamping pipes I’m going to bleed the brakes anyway so might as well let the old dirty fluid drain through.
I'm musing it. Will see.
My concern is that i'd get air into all of the other brake lines and have to bleed them all, so it seems thats not going to happen if i let that line and the master cylinder drip out and empty?
if you've not changed the brake fluid, this is a good time to do it. after 4 - 5 years the fluid will absorb moisture and make the brakes more spongey. it is also likely if it gets to hot that the water content boils which seriously affects the brakes.
I've topped up when i had to and bled the fronts a little, but other than that its probably the same fluid from car manufacture. I'll not worry about it then, and just let it be. Bleeding them all wouldn't be that much bother anyway. (y)
