toby14692
Bit of an odd one this time, the whip has started coming up with bulb failures nearly every time I press the brake pedal whils driving. The screen says check rear LHS turn light or the fog light. I have check the back end and the fogs and indicators are working fine. If i happen to be indicating left at the time, the indicator will blink rapidly as if a bulb was out but then return to normal. Could this be a bad earth of some kind?
Anyway if anyone has seen this before or knows anything about it, some info would be much appriciated.
Regards,
Toby
Regards,
Toby
